Activity Forums VEGAS Pro Struggling With Making Image Smaller
  • Struggling With Making Image Smaller
    Posted by Ken Fisher on January 22, 2013 at 10:56 pm
    HiYa Guys!
    I come across this problem now and then with making still images smaller on Vegas. What happens is I’ve reached my limit or so it seems on making them smaller through pan and crop(PC). With the image below I’d prefer them even smaller but it seems I’ve hit a limit as the PC handles don’t pull any further. If that’s not enough, I can’t get the images to move on the screen where I want them. The example is the 1/2 forklift with a dotted line on the right hand side. If it’s moved any further right it disappears.
    I think I’ve tried nearly everything over the years to make this work, but to no avail. Something is missing.
    Sony Vegas Pro 11
    DVD Architect Pro 5.2
    Sony Vaio Windows 7 Home Premium
    Intel Core TM i7-2670QM CPU 2.20Ghz
    8 G RAM
    Sony DCR-VX2100
    Pete Baratta replied 6 years, 4 months ago 5 Members · 5 Replies
  • Tyson Onaga
    January 22, 2013 at 11:25 pm
    Use Track Motion to resize your workspace and P/C to move over the image.
  • Mike Thomas ii
    January 22, 2013 at 11:33 pm
    I will generally format and size my images in Photoshop before adding any stills into Vegas. Maybe your image ratio/size has something to do with it??
    https://www.wideopendoors.net/design/aspect_ratio_calculator.html
  • Ken Fisher
    January 23, 2013 at 12:05 am
    Track motion. PuuurFECT. Thanks Mike!
    Sony Vegas Pro 11
    8 G RAM
    Sony DCR-VX2100
  • Neven Mazic
    April 26, 2020 at 11:49 pm
    Is there a way to do it with track motion but to not need to use a new video track every time you need to add a new image?
  • Pete Baratta
    April 27, 2020 at 9:33 am
    Hi Neven,
    I usually add a picture or video on a blank track and use track motion as needed then, if I need to add another pic, I right click on the track, hit restore then start again, It’s really just animating
    the motion and not useful if you’ve got pictures that overlap each other… unless you render each
    picture motion segment then add them to a separate video track…confusing myself now, Pete.
