Activity › Forums › Adobe After Effects Expressions › Struggling with if/else with color input
  • Struggling with if/else with color input
    Posted by Sandro Tagliavini on May 8, 2024 at 11:24 am
    Hi there I have a simple expression:
    col = content(“Group 2”).content(“Fill 1”).color; white = hexToRgb(“ffffff”); if(col == white){0;}else{100;}
    I tried with 1 (=) sign or 3 (===) but then it just doesnt work when I change
    the color input (meaning it stays 0% with white (good) but it doesnt
    show 100% if it is any other color…(bad))
    any help is appreciated.
    cheers
    Brie Clayton replied 2 years, 4 months ago 3 Members · 4 Replies
  • Dan Ebberts
    May 8, 2024 at 12:56 pm
    It should work if you change your last line to this:
    col.toString() == white.toString() ? 0 : 100
  • Sandro Tagliavini
    May 8, 2024 at 1:33 pm
    Wow that worked like a charm.
    Thanks so much.
    Just curious, why does that look so
    different than the if/else statements
    I know..?
    Greetings from Switzerland
  • Dan Ebberts
    May 8, 2024 at 1:42 pm
    When they changed AE’s JavaScript engine, it would no longer accept single-line if-else statements without the full curly bracket treatment, so I pretty much switched to the conditional (ternary) ? : operator, which is a kind of if-else shorthand.
  • Brie Clayton
    May 8, 2024 at 3:46 pm
    Thank you for the solve, Dan!
