Activity Forums Adobe After Effects Struggling to import a huge image file into AAF, please help
  • Struggling to import a huge image file into AAF, please help
    Posted by Adam Dorsz on May 29, 2023 at 8:49 am
    Hi all,
    I have a huge image file:
    Format: .TIF
    Dimensions: 33871 x 14953 pixels
    File size: Almost 2GB
    Whenever I try to import this into my project, it tells me “Photoshop file exceeds image bounds limit” (error attached). My question is, how can I increase the image bounds limits? I am able to work with this image in Photoshop no problem, having only 32GB RAM.
    In case you would need to know what the image is, it’s a Adobe Firefly generated composite image that started as a 500x500px image and then was generated to its current dimensions.
    Andrew David replied 3 years, 3 months ago 3 Members · 2 Replies
  • Walter Soyka
    May 31, 2023 at 1:11 am
    After Effects can’t handle images beyond 30,000 pixels in either dimension. Maybe you can scale it down a little in Photoshop, or split it into a couple of tiles in Photoshop and composite them back together in After Effects.
  • Andrew David
    June 1, 2023 at 12:45 pm
    Reduce the file size.
