Activity Forums Adobe InDesign Struggling from PageMaker!
  • Struggling from PageMaker!
    Posted by Glenn Woiler on May 18, 2006 at 6:46 pm
    Can someone tell me how to make an object “non-printing”? This was fairly easy in PageMaker. But I am loosing it… trying to figure out what InDesign might call it and where it is found. A graphic artist here has never used that feature even though she is really good at what she does. So…. How can I make a line, or circle that I have created… visible but it won’t print?
    thanks… I know it must be simple… but I am being forced to move over to this new program. 🙂
    Glenn
    Glenn Woiler replied 20 years, 3 months ago 2 Members · 6 Replies
  • Alex Salerno
    May 19, 2006 at 1:23 am
    From the WIndows Menu select the Attributes pallett, then select “non-printing”.
    Note: such non-printing objects will not appear on screen in the preview mode.
  • Glenn Woiler
    May 24, 2006 at 5:16 pm
    Thanks… that worked. Now… how to get a drop shadow on text? I see how to do it to an object… but not text??? ahhhh
  • Alex Salerno
    May 24, 2006 at 5:29 pm
    Select the text box with the selection tool (NOT the Direct Selection Tool). Make sure the text box doe NOT have a fill assigned to it. Then (I use the object contextual menus) control-click (or right-click on PC) the text box and select Drop Shadow, etc.
    The trick is to have no fill assigned to the box/frame.
  • Glenn Woiler
    May 24, 2006 at 8:24 pm
    Thanks. I use PM 6.5 at home on a PC and PM 7.0 at work on a MAC but OS 9.x is a pain to use from OS X so they want me to get with it on InDesign. Lots of familiar things but other things are wierd. Thanks again. Glenn
  • Alex Salerno
    May 25, 2006 at 1:46 am
    I am a Quark 6.5 convert who will not be upgrading to Quark7!
  • Glenn Woiler
    May 31, 2006 at 6:31 pm
    Quark… hmmm… I have not used that since the mid 90’s when we were testing Quark and pageMaker because we wanted to move away from… VENTURA!!!
