Activity Forums Adobe After Effects Stroke on green screen material
  • Stroke on green screen material
    Posted by Niklas Welander on April 15, 2009 at 3:08 pm
    Hi folks, this is my first entry, not that it matters.
    I’m working in After Effects (CS4) and I have recorded good quality green screen material. With this I of course want to key light away all the green but then I also want to add a stroke (white) around the body of the actors in the film.
    When I tried to do this earlier I tried simply using stroke but then the stroke appeared around the whole footage area instead of just the character. I also tried dublicating the material and giving the bottom layer a white fill. It somewhat gives the effect I’m looking for but the dimensions become all wrong and so therefore it cannot be used.
    Please help me. I’m new to After Effects but I really need this to work so any help will be appreciated. Thanks
    Tony Silva replied 17 years, 4 months ago 4 Members · 3 Replies
  • Todd Kopriva
    April 15, 2009 at 4:13 pm
    This tutorial from Aharon Rabinowitz might be what you’re looking for.
    [update: Heh. It looks like Dave and I were typing and thinking the same thing. He’s just faster.]
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Jason Milligan
    April 15, 2009 at 4:57 pm
    You can also try applying your stroke as a layer style instead of an effect.
  • Tony Silva
    April 15, 2009 at 10:27 pm
    when you duplicated your layer and applied a white fill, did you then just scale the footage? if you use a simple choker to expand the matte before you apply your fill, then it should be what your looking for.
    The stroke effect needs a path to work, check out the mentioned tutorial if you wanna go that route.
