Activity Forums Adobe After Effects Stroke Layer Style Aliasing Issue
  • Stroke Layer Style Aliasing Issue
    Posted by Mark Walczak on July 21, 2009 at 4:31 pm
    Hey Everyone,
    Before I explain my issue, allow me to say that I have already checked these forums to no avail:
    https://forums.creativecow.net/readpost/2/952542
    https://forums.creativecow.net/thread/2/930194
    My problem is that my stroke layer style appears not to be anti-aliased. When looked at 100%, the stroke edges appear to be choppy and distorted. I realize that a solution to this may lie in precomping, but I do not want to soften my entire composition – only the edges of the layer style – make sense? Please let me know if I need to be more detailed in my description, and thank you so much in advance for your help!
    PS – Perhaps I should mention that I am applying the layer style to a solid that is masked into a certain shape.
    What makes you explode?
    http://www.explosivegraffix.com
    Paul Roper replied 1 year, 4 months ago 4 Members · 4 Replies
  • Adolfo Rozenfeld
    July 21, 2009 at 7:26 pm
    The Stroke layer style is anti-aliased.
    Is it possible that you have a non-square pixel Comp and that the PAR correction button is enabled? When you do that, After Effects uses a draft-like filtering option for Comp previews.
    Adolfo Rozenfeld · Adobe
  • Mark Walczak
    July 21, 2009 at 8:18 pm
    Thanks for your reply, Adolfo.
    Unfortunately, I’m working entirely with square pixels. Is there any other type of filtering I should be aware of? The stroke looks fine when applied to text, but always looks eaten away when working with masked solids. I perhaps should have mentioned that I am working in CS3.
  • Jim Dodson
    July 22, 2009 at 1:16 am
    …just thinking out loud here,
    Have you tried lowering the “SPACING” to 0%?
    Jim Dodson
    8 Core Intel — Mac – OSX
  • Paul Roper
    April 28, 2025 at 10:48 pm
    (Only nearly 16 years later)…
    The Layer Style > Stroke, in my experience, is nearly always aliased and ugly. I found my way here doing a quick search for answers – to no avail. It has nothing to do with pixel aspect ratio.
