Activity Forums Adobe After Effects Stroke effect like in Photoshop!
  • Stroke effect like in Photoshop!
    Posted by Editing-jos on January 28, 2006 at 7:17 pm
    Hey
    Now this has been something I seem not to find.
    A STROKE effect like we have in Photoshop!
    Where it takes the Transparency/Alpha and use that edge for the stroke!
    Also the stroke has HARD edges (squared) and not round like the ‘stroke’ in AE.
    Its a b*thc that we have to use MASKS in AE to get a stroke working.
    Is there a plugin i’m missing or maybe some Third Party that does the trick?
    (make strokes based on transparency edges)
    tnx
    Alan Langdon replied 15 years, 2 months ago 4 Members · 5 Replies
  • Mike Clasby
    January 28, 2006 at 8:15 pm
    Well, you’re right, but there’s always (usually) a way in AE.
    Layer > Auto-Trace (drop the Tolerance and Threshold down to about 1) gives you a mask, lickity-split. (Skip a few paragraphs if you don’t have Auto-trace).
    Add Stroke.
    Render > Scribble also give you edge options for wiggly wider edges.
    My fav with a mask is Render > Audio Waveform. (Nice round edges)
    Check the Composite on (at the bottom), Audio Layer > Choose a layer WITHOUT sound for a solid (quiet) line, or use an audio layer if you want the outline to wiggle with the beat.
    Path > Mask, Displayed samples – up this to cover the outline, animate this to have the outline draw itself on in a really cool way, surprised I don’t see this used.
    Waveform Options > Analog Line (default). Anyway this makes for wild outlines.
    You can control, Inner and Outter Color, softness, thikness. (Add Glow and maybe a wiggle expression on softness for a neon look)
    So without masks (no Auto-trace) you can use:
    Stylize > Roughen Edges (choose Roughen Color with Fractal Influence down to 0,Border about 0.5 (this needs to be low because the Roughen eats into the image,
    Fractal Influence 0. This give a very fine outline on the INSIDE of the alpha image, it eats in. It can be nice for say a cartoon outline when a layer of the same color – say a hand of the same color as the body passes in front
    of the other, gives it a different outline so they don’t blend into the same color, yikes too much info here, but I just did it on a cartoon hand over cartoon body).
    Also without mask, try Render > Vegas (with Selected Contours (1 usually gives you the outside), and Rendering>Start, Mid-point, and End Opacity all set to 100%, crank the Width up a bit, choose a color. This works better than you might think and is the sole option if you can Auto-trace to make your mask(s).
    Use both of the above if you want a two color outline, or two close together colors that blend into a softer feathery edge.
    Otherwise its generate a path in PS then imoprt into AE for a mask.
    Wow, this just shows how far I’llgo to avoid working on my project, and with a deadline looming no less. Bad.
  • Editing-jos
    January 28, 2006 at 8:19 pm
    LOL.. I’m the same way with Deadlines.
    You need to be almost DEAD to do the best work.
    Thanx for the info.
    Still we need a normal STROKE plugin 🙂
    I think its strange no Third party packages does that!
  • Mike Clasby
    January 28, 2006 at 8:26 pm
    Maybe there is a third party out there, I most just have the AE plugs.
  • Filip Vandueren
    January 29, 2006 at 4:34 pm
    I Think Ice FX used to have a Stroke effect.
    BTW, YikesMike that Vegas trick is super-handy.
    I’ve never ever opened Vegas before.
    Some more tricks to get it more Photoshoppy:
    if you want the stroke to be “outside”: Double the width & set Rendering Blend-mode to Under.
    if you want the stroke to be “inside”: Double the width, and add a CC Composite-effect set to “Stencil Alpha”
    As a side note, Photoshop’s stroke does realy ugly stuff to semitransparant layers, so I don’t think anyone would want to replicate that behaviour.
  • Alan Langdon
    July 21, 2011 at 2:43 am
    My favorite tip is to use the GLOW effect under Stylize. I play with threshold, radius and intensity and it usually gets me a good o’l stroke effect!
