Activity Forums Adobe After Effects stroke effect dissappears on ram preview
  • stroke effect dissappears on ram preview
    Posted by Ted Intorcio on July 24, 2020 at 4:03 pm
    I’m doing a RAM preview on an HD res comp. The stroke width is 1.5 thick and I’m previewing full res and at 100% size but the stroke disappears nonetheless. If I drag the time line around, it shows up and if I render, I see the stroke. But RAM previewing? Nothing. BTW I have fast preview turned off. Is there a setting I’m missing? Tried this in both Ae 2019 and Ae 2020. Same result.
    Ted Intorcio replied 6 years, 1 month ago 2 Members · 2 Replies
  • Walter Soyka
    July 24, 2020 at 9:11 pm
    Have you tried clearing the cache? (Edit > Purge > All memory & disk cache…)
    Failing that, can you share some screenshots of your complete UI so we can see what you are seeing?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Ted Intorcio
    July 24, 2020 at 9:37 pm
    Hey, sir. Clearing the cache does nothing, unfortunately. You can see the screen capture of the UI here
    https://vimeo.com/441466034
