Activity Forums Adobe After Effects Stroke effect brush size
  • Stroke effect brush size
    Posted by Kurt Hudson on May 21, 2009 at 6:44 pm
    Im attempting to do the stroke effect in after effects cs4 on a logo with a very bold font. Ive increased the brush size as much as possible (50.0) and its not covering the whole entire text which results in it cutting off when I change it to reveal original image. What should I do????
    Kurt Hudson replied 17 years, 3 months ago 3 Members · 4 Replies
  • Kurt Hudson
    May 21, 2009 at 8:04 pm
    I thought of doing that and tried it a few times somewhat successfully, I was just hoping there was an easier way.. thanks tho! any other possible solutions?
  • First Last
    May 21, 2009 at 8:30 pm
    Make your text smaller so that the brush stroke can cover the text. Then make a pre comp and scale it up to the size you want.
    I haven’t actually tried that but I think it should work.
    Production Associate
    Bend, Oregon, United States
  • Simon Bonner
    May 21, 2009 at 8:47 pm
    Third (possible!) solution:
    You could try adding a simple choker effect to the text layer below the stroke effect. Set the value into negative numbers. Now when you animate the stroke’s start/end properties, you should see the text plus a border being revealed. We don’t want to see the border, so duplicate the text layer and, on the bottom instance, delete both effects and set the track matte to alpha.
    Simon Bonner
    youtube.com/simonsaysfx
  • Kurt Hudson
    May 22, 2009 at 1:30 pm
    Thanks to all of you !
