Activity Forums Adobe After Effects Stroke edges
  • John Cuevas
    September 25, 2013 at 3:20 pm
    Really you can’t tell much from that picture. If you upload your project(really just that comp), I’ll take a look and see if there’s settings issue.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Marc Lucas
    September 25, 2013 at 3:41 pm
    The bottom stroke is jagged might of been the position of the solid layer in the Comp?
    I have changed the solid now and used a Shape layer and all is fine.
    Thanks for the reply!
