Activity Forums Adobe After Effects stroke craziness
  • stroke craziness
    Posted by Antony Buonomo on September 7, 2005 at 4:17 pm
    I take a map (jpg), and then put a solid layer above it. Set both layers to 3D. I then set up a camera and few simple moves.
    I draw a few lines (mask paths) on the solid and then apply a Stroke effect (not 3D stroke) to it.
    Here’s the crazy bit: everything works fine until I hit the ‘continuous rasterization’ on the solid layer. Suddenly the mask paths seem to jump position in 3D space. In fact, if I use a ‘top’ or ‘left’ view the lines don’t actually move (in the X, Y, Z pos) but in the regular camera view they have shifted considerably. What am I doing wrong?
    A
    Vertigo Productions
    https://www.vertigo.co.uk
    A
    Vertigo Productions
    Antony Buonomo replied 21 years ago 3 Members · 5 Replies
  • Stone Reader
    September 7, 2005 at 7:06 pm
    Hmm, I had your problem before and solved it, but I can’t remember everything I did.
    I know one problem was that the comp had to be Square Pixels, not D1. Try that and see if it works. I’ll try to dig up what else I may have done.
  • Antony Buonomo
    September 7, 2005 at 10:11 pm
    is it a known bug?
  • Stone Reader
    September 8, 2005 at 2:07 am
    Don’t know if it’s a bug or something that has to do with the way the software works. Did you try it?
  • Steve Roberts
    September 8, 2005 at 2:44 am
    Boy, that’s annoying. It seems to make the stroke “2D”, or flat to camera. The mask still follows the layer, but the stroke forgets that it’s 3D. Bummer.
    No solution yet — sorry.
    Steve
  • Antony Buonomo
    September 8, 2005 at 9:14 am
    Thanks guys. The only solution I have found is to pre-comp the solid layer, however this has other implications (why does pre-comping a layer and then applying ‘collapse transformations’ effect the lighting in the main comp?)…
    Cheers
    A
