Activity Forums Adobe After Effects Stroke and Fill Shapes
  • Stroke and Fill Shapes
    Posted by Kris Sheehan on December 5, 2016 at 8:57 pm
    I am having an issue in AE 2017 where I cannot get strokes or or fills to show up on my shapes. If I create a shape layer, go to the contents folder, and drop down to stroke nothing happens when I start adjusting the stroke width, color, or opacity. I have the same lack of results is I adjust the fill. I have tried adding a stroke from the effects panel to it and it give me only a none option when I select which path I would like the effect to link to. It will let me add a stroke and fill by using the tools in my tool bar, but I need to be able to have the stroke follow the path and generate. Is anyone else having this issue? Have you found a way around it?
    Kris Sheehan replied 9 years, 9 months ago 4 Members · 6 Replies
  • Walter Soyka
    December 5, 2016 at 10:08 pm
    Can you post a screenshot showing your entire UI, with the shape layer twirled open?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Kris Sheehan
    December 5, 2016 at 10:36 pm
    I figured out if I add it from the toolbar I can manipulate it in the drop down, however I am not seeing the option to animate the pat, or draw it, like you could in previous versions.
  • Roei Tzoref
    December 6, 2016 at 12:38 am
    [Kris Sheehan] “I figured out if I add it from the toolbar I can manipulate it in the drop down”
    you can add it either way. it appears you are trying to work intuitively with Ae and this is not so easy. especially with shapes. invest some time and read how they work. here’s a very good reading section about shapes:
    https://www.crishdesign.com/books/Creating-Motion-Graphics/CMG5/CMG5_32_ShapeLayers_exerpt.pdf
    here’s the adobe help files section where I took this resource from:
    https://helpx.adobe.com/after-effects/using/overview-shape-layers-paths-vector.html#about_shapes_and_shape_layers
    after a nice reading everything will makes sense. for example the reason you can’t manipulate your paths is because you choose to draw a parametric shape instead of a bezier shape. parametric shape offers other ways of manipulating the shape than manually adjusting vertices or paths.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Greg Gesch
    December 6, 2016 at 12:41 am
    Hi. Does it have anything to do with your Fill and Stroke being set to None/Alpha on the toolbar at the top of your screen? Do you mean the Add button is not opposite Contents in your Layer’s dropdown?
  • Roei Tzoref
    December 6, 2016 at 12:46 am
    [Greg Gesch] “Does it have anything to do with your Fill and Stroke being set to None”
    they are somewhat connected.
    for example if you set your shape layer’s fill in the toolbar to none, then it’s switching the eyeball off from the fill parameter of that shape.
    Roei Tzoref
  • Kris Sheehan
    December 6, 2016 at 1:47 pm
    Thanks for the input. It all make sense now. It turns out most of my problem was that I haven’t done anything with shapes in AE for a long time and was forgetting a few steps.
