Activity › Forums › Adobe After Effects › Stroke a path
  • Stroke a path
    Posted by Jack Stone on November 7, 2005 at 8:21 pm
    I’ve created a series of paths in Illustrator and imported them as separate layers into AE. How do I stroke/animate colors on the path? I’ve created paths in AE and stoked them with the Vegas effect, but I’m not able to stroke the imported paths from Illustrator. Thanks in advance.
    Jack Stone replied 20 years, 10 months ago 2 Members · 2 Replies
  • Chris Smith
    November 8, 2005 at 1:49 am
    I assume they are now masks? If not you can copy/paste the strokes from Illustrator to AE and they will paste as masks. Once they are masks, just use the stroke effect. You can animate the start and end point. If you want a stroke that tapers and can be moved in 3D space with some 3D distortion capabilities then you can use Trapcode’s “3d stroke”. trapcode.com
    Chris Smith
    https://www.sugarfilmproduction.com
  • Jack Stone
    November 8, 2005 at 3:52 pm
    Chris
    Thanks. It’s working great.
    JS
