Activity Forums Apple Final Cut Pro Legacy Strobing of insert footage on timeline
  • Strobing of insert footage on timeline
    Posted by Thom Sullivan on March 29, 2006 at 6:05 pm
    A problem has appeared on one of the laptops we have at our studio. For some unknown reason all insert footage plays back strobed when you drag it to the timeline AND if it is played in the Canvas windows. We suspect that someone may have inadvertanely selected a setting, but we cannot reverese the strobe affect. If you burn a project to a DVD disc it is not strobed. If you firewire out to a digital tape deck the project footage is strobed.
    We have a second laptop and theis strobed look is not present. That is why we think something has been selected that shouldn’t have been.
    Any assistance is greatly appreciated.
    Thom Sullivan/Comcast
    Thom Sullivan replied 20 years, 6 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    March 29, 2006 at 10:46 pm
    Sort of sounds like a field dominance problem. If you’re working in DV, the the LOWER field should be set to be the dominant field. (Lower field first). You can change this back and forth to see if this is the problem, by clicking on this property in the Field Dominance column in the Browser.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Thom Sullivan
    March 30, 2006 at 4:02 pm
    Thanks Jerry. I’ll check out this option. Thom
  • Thom Sullivan
    March 30, 2006 at 4:59 pm
    Jerry, Sutle strobing is still present. I’m not sure what else to try. Thanks. Thom Sullivan
