Strobing Object not coming through in subsequent nested compositions
Hello,
So I am working in After Effects CS6 on a Windows laptop.
I have a composition with an expression that has an object’s opacity strobing back and forth between 50% and 100% every frame.
The expression I’m using is such:
loopOut(type = “cycle”, numKeyframes = 0)
When I preview the animation in the original composition, it strobes just fine all the way through.
I then have that composition, inserted into a second composition. The strobing seems to work fine upon preview of this second composition.
I then have this second composition, inserted into a third composition. The strobing seems to work fine upon preview of this third composition.
I then have a this third composition, inserted into a fourth composition. It is at this point that the strobing no longer comes through. The object remains at 50% opacity, as though it doesn’t have any expression attached to it at all.
Is there a limit to the number of compositions one can nest an expression into before it no longer comes through?
Thanks in advance for any help anyone can give.
loopOut(type = "cycle", numKeyframes = 0)
