Activity Forums Apple Final Cut Pro Legacy Strobing Graphics
  • Strobing Graphics
    Posted by Stephen Smith on December 15, 2010 at 4:13 pm
    My animation is strobing real bad. I’m working in a 23.98 timeline. Here are my Project Settings:
    Frame Size: 1920 x 1080, Aspect Ratio: Square, Compressor: XDCAM EX 1080p24
    The motion graphics where created in a Motion file with the same project settings. My graphics with big text really strobe a lot. I feel as if there is one setting or codec or something that is wrong. I can’t seem to figure out why it is strobing so bad. I understand 24fps strobe, but not as bad as my graphics are.
    I’m viewing it on a broadcast monitor set to “AJA KonaLH 1080p23.98 8 Bit”.
    I took the same Motion project file and changed it’s frame rate to 29.97 and then brought it into a new FCP project file set to the 29.97 frame rate and then the animation looks perfectly smooth. I took that 29.97 animation and ran it through Cinema Tools and conformed it to 23.98 and then brought it back into my 23.98 FCP timeline and it looks no different then the other animation. I can’t figure out how to smooth this out.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
    Walter Soyka replied 15 years, 9 months ago 2 Members · 5 Replies
  • Walter Soyka
    December 15, 2010 at 6:54 pm
    [Stephen Smith] “I took the same Motion project file and changed it’s frame rate to 29.97 and then brought it into a new FCP project file set to the 29.97 frame rate and then the animation looks perfectly smooth. I took that 29.97 animation and ran it through Cinema Tools and conformed it to 23.98 and then brought it back into my 23.98 FCP timeline and it looks no different then the other animation. I can’t figure out how to smooth this out.”
    I didn’t quite understand what you were referring to here — when you conform a clean 29.97 clip to 23.976, does it strobe or not?
    You may need to alter the speed of the movement a little, or add a little (or a lot) of motion blur.
    Any chance you can post a short clip?
    Walter Soyka
  • Stephen Smith
    December 15, 2010 at 7:02 pm
    Walter,
    When I conform a clean 29.97 clip to 23.976 (23.98, apple rounds up the number) it strobes just like the clip created in 23.98. I can’t figure out what is wrong with the cadence.
    Here is a link to the clip:
    Strobing Animation
    As you can see the movement is not crazy and should look great. Movie title opens such as the one on Catch Me if You can has text moving at the same speed but looks great.
    I did try to add Motion blur and it still strobes.
    Stephen Smith
  • Stephen Smith
    December 15, 2010 at 7:04 pm
    Also, keep in mind that the sample is small. It looks real bad when you look at it on a big monitor and even worse when projected off a blue ray.
    Stephen Smith
  • Walter Soyka
    December 15, 2010 at 8:30 pm
    Hi Stephen,
    I think that this move is just too “big” for 24p. Changing that camera move or pulling out of that tight close up are probably your best bets.
    If you watch the Catch Me If You Can title design, you’ll see that there’s a lot going on: there’s some pretty heavy motion blur in places, as well as those intentionally-staccato-looking cutout animations. They have big objects, and they have drastic moves, but they rarely combine them.
    There is also some strobing, but it’s never where you’re looking. They draw your attention into something with clean, subtle motion, while the big moves are causing strobing around the periphery — just like how a magician uses misdirection to pull off an illusion.
    Walter Soyka
  • Walter Soyka
    December 15, 2010 at 8:59 pm
    [Walter Soyka] “Changing that camera move…”
    I should clarify this a little: a cinematographer will move with the subject to minimize strobing. Instead of just sliding the camera over the headline (dollying), if you lock its point of interest on the headline while the camera moves (panning with the subject while dollying against it), it will help minimize strobing.
    Walter Soyka
