Activity Forums DSLR Video Strobelights / Rolling Shutter
  • Strobelights / Rolling Shutter
    Posted by Pete Burger on June 30, 2012 at 1:44 am
    Any ideas how to deal with rolling shutter issues caused by strobelights from still-cams? You know, when half a frame is overexposed, the rest looks good…
    We shot an event at the Munich Filmfestival with a 7D and a 550D today and we were surrounded by photographers. A flurry of camera flashes (Hope this is the right translation – I had to look it up) when certain celebs showed up. No two seconds without a flashlight going off…
    Any ideas or suggestions what can be done in post more than welcome!
    Thanks in advance!
    “Tragedy is a close-up; comedy, a long shot.” – Buster Keaton
    Me on Twitter (english/german)
    https://twitter.com/FastFoodVideo
    Pete Burger replied 14 years, 1 month ago 2 Members · 2 Replies
  • Steve Crow
    June 30, 2012 at 3:29 am
    Peter I don’t think there is anything you can do to correct this – the camera is capturing exactly what happened. In theory, if you removed every other frame (the frames filled with a flash) and then replaced that frame with a copy of the one before or after it, then all the flash frames would be removed but I still think it would look weird (slow motion? and off-sync)
    There are tutorials online for ADDING flash effects to your video but I don’t think there can be any on removing them…maybe there is a creative work around I haven’t thought of however, let’s hope! 🙂
    Steve Crow
    Crow Digital Media
    http://www.CrowDigitalMedia.com
  • Pete Burger
    June 30, 2012 at 2:00 pm
    [Steve Crow] ” I don’t think there is anything you can do to correct this – the camera is capturing exactly what happened”
    That’s what I thought as well… We discussed the problem before the shoot, but had no idea how to solve it. I hoped that – like in other projects – I would be able to “cut around” the flashes most of the time, but no chance here …
    I thought about maybe stylizing the footage if everything else fails. Luckily this is not supposed to be a documentary but more like a “music-video-style mood-clip sort of thing”…
    We had to capture the DJ-performance of an internationally very well-known musician, producer and film-composer and create a promo-clip for him.
    [Steve Crow] “In theory, if you removed every other frame (the frames filled with a flash) and then replaced that frame with a copy of the one before or after it, then all the flash frames would be removed but I still think it would look weird (slow motion? and off-sync)”
    That’s basically a great idea. Sync is not a problem. We won’t use the audio anyway, but get a completely different track. Strobing could be a problem, because of the missing frames… Hmmm… Maybe in After Effects: Remove the frame and interpolare the gap… Could work for single flashes, but we had a “thundestorm”…
    But I think this could be a solution for a couple of shots. If I had to do all of them… Don’t even want to think about it 😉
    Thanks a lot for the suggestion, Steve! Much appreciated! I’ll definitly play around with that!
    Edit: Just want to add: The flashes per se don’t bother me at all. It’s the “half-frame” issue… Maybe (for selected shots): Mask the correctly-exposed part of the picture out and increase exposure for that part in post… Will try that as well
