Strobe Effect In Vegas
Posted by Clay Dempsey on February 17, 2007 at 6:34 amDoes anyone have a tutorial on how to make flashes in Vegas 7?
Mike Kujbida replied 19 years, 6 months ago 3 Members · 7 Replies -
Gary Kleiner
February 17, 2007 at 7:07 amUse either a short Fade Through White (in the dissolves section)transition, or on a track above, place a short white clip (media generator > solid)which fades quickly in and out.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Clay Dempsey
February 17, 2007 at 6:26 pmThank you. I can see that. I am having an issue setting up transition time now. If I can figure out how to shorten it I could accomplish what I need.
Gary Kleiner
February 17, 2007 at 7:14 pm[cladsco] “If I can figure out how to shorten it I could accomplish what I need.”
Less overlap = shorter transition
Gary Kleiner
Clay Dempsey
February 17, 2007 at 9:43 pmi get that, but i can’t seem to make it quite small enough. i have the solid white in the middle of two video tracks. the white is showing up way to long and i can’t make it smaller with the mouse.
Gary Kleiner
February 17, 2007 at 10:09 pmWhat happens when you try to make it smaller? How are you trying to make it smaller?
The shortest it can be is 1 frame.Gary Kleiner
Clay Dempsey
February 17, 2007 at 10:29 pmI’m trying to make it smaller with the mouse. Are there properties I can open up?
Mike Kujbida
February 18, 2007 at 5:14 pmJust place the cursor at the right or left side of the transition and drag it forwards or backwards to the desired length. It helps to be zoomed in on the timeline quite a bit.
