Activity Forums Adobe Premiere Pro Stripping out black bars?
  • Stripping out black bars?
    Posted by John Riker on March 30, 2020 at 10:43 pm
    When I open my 4K file, it “looks” like it has physical black bars.
    When I used to convert files to WMV, Expression encoder had a way to change the size of the height without stretching or anything. So a 1920 x 1080 file would end up being 1920 x 800 without the bars. Now on my screen it did not stretch to full screen. There were still the bars on screen but from what I can tell they weren’t in the file then. Would think you wouldn’t want the back bars IN the file? Any way to strip them out?
    John Riker replied 6 years, 5 months ago 2 Members · 2 Replies
  • Tero Ahlfors
    March 31, 2020 at 11:35 am
    What is the source resolution of the footage and what are your sequence settings? If you fit, for example, DCI 4K (4096×2160) in a 16:9 sequence you’ll have bars because the image is wider.
    If the aspect ratios match then you can just re-export the file and crop the extra area.
  • John Riker
    March 31, 2020 at 11:52 am
    Thanks for the reply. Source resolution is 3840 x 2160 (1.0).
