Activity Forums Apple Final Cut Pro Legacy Stripping alpha from QT file
  • Stripping alpha from QT file
    Posted by Patrice Freymond on September 25, 2010 at 6:25 pm
    Hi everyone,
    after searching these forums and the web:
    is there a way to obtain the alpha layer of a qt file so as to modify it? Basically, turning a qt file (animation codec, or prores 4444) into two separate files?
    thanks in advance
    Patrice Freymond replied 15 years, 7 months ago 4 Members · 6 Replies
  • John Fishback
    September 25, 2010 at 6:49 pm
    See if this from Ken Stone’s site helps.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
  • Patrice Freymond
    September 25, 2010 at 7:24 pm
    Exactly what I was looking for.
    Did not think about using Motion for this.
    Thank you
    patrice
  • John Fishback
    September 25, 2010 at 8:16 pm
    I’m glad it worked out.
    John
  • Tom Wolsky
    September 25, 2010 at 10:02 pm
    Are you trying to export a matte layer from FCP? If so you can do that in FCP without going to Motion.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Rafael Amador
    September 26, 2010 at 2:42 am
    FC don’t have the export only Alpha option, but you can export a B & W matte to be used for Luma Matte in FC or interpreted as an Alpha Channel for AE, Motion, etc.
    – Put a black in Layer 1 and a white in Layer 3.
    – In Layer 2 set the picture with the Alpha Channel.
    – Set Layer 3 as “Travel Matte Alpha”.
    Export in whatever codec you prefer.
    Rafael
    http://www.nagavideo.com
  • Patrice Freymond
    September 26, 2010 at 7:59 am
    Well,
    at least two solution to my problem.
    I am lucky 😉
    Thank you all
    patrice
