Activity Forums Apple Final Cut Pro Legacy Striping FW-800 Drives as 1 RAID
  • Striping FW-800 Drives as 1 RAID
    Posted by John Dehn on July 7, 2005 at 12:18 am
    Does anyone have experience in using Apple Disc Utility to stripe 2 FW-800 Drives as a single RAID in the quest for greater thru-put. I have a G4, 1.25, with 2 G-RAID 500s, and 2 Adaptec FW-800 PCI cards and an Aurora Igniter RT. Striping went without a hitch, playback in FCP looks okay, but playback through the Aurora stutters and is interspersed with black frames. Since it looks okay in the quicktime viewer, I’m starting to wonder about a conflict with the Aurora card.
    Any thoughts would be great!
    Thanks.
    -John
    Nathan Mobley replied 21 years, 1 month ago 4 Members · 3 Replies
  • Tom Matthies
    July 7, 2005 at 2:40 am
    I’m running several striped pairs of Lacie 250Gb Firewire 800 drives thru an Aja La without any problems at all. I’m controlling them by Lacie FW-800 PCI cards running in a Dual G4 1Ghz. The G4 is running OS 10.3.8 with FCP 4.5. Solid as a rock. I’m giving each drive it’s own port on the cards. None of the drives are daisy chained. It works well up to 8-bit uncompressed. I’ve not tried it with 10 bit, however.
    I’m just putting the finishing touches on a Dual 2.3 Ghz with the same setup running Tiger with FCP 5. I’ll see how that combination works in a couple of days.
    Tom
  • Peter
    July 7, 2005 at 8:20 am
    As far as I know the fw 800 is still screwed up. I was running some test the other day and the read or write was much slower I can’t remember which but one is much slower. It is the apple operating system from what I understand.
  • Nathan Mobley
    July 7, 2005 at 2:15 pm
    John,
    I have a very similar setup to Tom’s, except that I use the Blackmagic SP card and OS 10.3.9. Additionally I have put more than one drive on each Lacie firewire 800 card. My setup has been very reliable also.
    Nathan
