Hi Harald
Those lines are scan lines. What we are probably seeing is half a frame. Interlaced video is composed of two half frames to make one. It will first scan the odd lines (1,3,5,7, etc…) and then scan the even ones (2,4,6,8, etc…) in order to get a complete frame. You don’t get that with progressive as opposed to interlace. I can also see that the capture of your video has a lot of ”blockyness”. You can see it mostly in the black parts. It’s a dead giveaway for compression.
Not knowing what were the specs of the original file and what were the render parameters, that’s as much as I can tell you.
Cheers !
PC Win 10 Pro 64-bit 16gb
Ryzen 9 3900X 12 Core 4.60GHz
Radeon RX 5700 XT
Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
Vegas Pro 16, User since Vegas 3.0
\’\’When the cutting stops, the editing begins…\’\’
