Activity Forums Maxon Cinema 4D strip light across surface
  • strip light across surface
    Posted by Andy Stokes on August 15, 2005 at 1:08 pm
    Hi all,
    I have a flat surface which has a material with a high specularity. I also have a tube light. When the light catches the surface I see a spherical highlight ? I had expected that using a tube light would render a wider “tube” of light across the flat surface instead of a circle with falloff. I hope this is clear.
    Is there any way to get around this or is there another way to get a smooth shean (like a diagonal line) across the face ?
    Cheers,
    Andy
    Chris Smith replied 21 years, 1 month ago 2 Members · 1 Reply
  • Chris Smith
    August 15, 2005 at 2:29 pm
    My only thought is to use the reflection channel instead of specularity and make the tube light visible so it is actually reflecting the tube itself.
    Chris Smith
    https://www.sugarfilmproduction.com
