Activity › Forums › Adobe After Effects › stretching out Pro comps to fit main comp
  • stretching out Pro comps to fit main comp
    Posted by Piff Aroni on January 29, 2010 at 6:31 am
    say I have some pre comps that are not stretched out to the time of the footage, how can I stretch the pre comps out to make them sit the main comp?
    John Cuevas replied 16 years, 8 months ago 2 Members · 1 Reply
  • John Cuevas
    January 29, 2010 at 2:07 pm
    Couple of ways. First open each precomp and press “cntl+K” to access the composition settings and change the duration to match the time of your comp.
    Second way would be to select the precomp layers and enanble time remapping(“cntl+alt+t), move the last keyframe to the end of the composition and then press “alt + ]” to stretch out the layer. If your precomps are already the right length then going to the end and pressing “alt + t” would do the trick.
    Timeremapping though will add frames to you precomp, possibly making effects, video, ect…look book.
    Johnny Cuevas, Editor
    http://www.ckandco.net
