Activity Forums VEGAS Pro Stretching my 1.85:1 to 16:9
  • Stretching my 1.85:1 to 16:9
    Posted by Garðar Garðarsson on April 30, 2014 at 3:41 pm
    Hi. A long time reader and first time poster.
    I have a annoying problem.
    I have 1.85:1 material shot from a Canon C300 and it is stretching to 16:9.
    I’m guessing this is a straightforward no-brainer issue but I’m wrapped up in so many things at the moment I can not at this point think straight.
    I’ve been trying to google the problem but all google finds is how to crop HDSLR footage etc.
    I’m thinking I may have a bad codec, or simply my properties settings are wrong:
    Template: Custom (1920×1080 25,000fps)
    With: 1920
    Height: 1080
    Field order: None (progressive scan)
    Pixel aspect ratio: 1,0000 (Square)
    Output rotation: 0° (original)
    Frame rate: 25,000 PAL
    Stereoscopic 3D mode: Off
    Pixel format: 8-bit
    Compositing gamma: 2,222 (Video)
    Full-resolution rendering quality: Best
    Motion blur type: Gaussian
    Deinterlace method: None
    BOX NOT CHECKED: Adjust source media to better match project or render settings.
    *** Note.
    I’m not trying to put letter boxes on top and on bottom, I just want the footage not to be stretched.
    When I change the properties settings to 1920×1040 for example it simply crops into the footage when I go to 1.85:1 Academic aspect ratio in Pan/Crop. When it’s at default it leaves black space at the sides.
    Can someone point out to me what may be the problem?
    P.S. When I play the media in VLC it also stretches to fill out my monitor at 16:9, not the original 1.85:1 (the reason I’m thinking bad codec).
    I am using Vegas Pro 11
    Thank you.
    John Rofrano replied 12 years, 4 months ago 2 Members · 1 Reply
  • John Rofrano
    May 4, 2014 at 11:05 am
    [Garðar Garðarsson] “I have 1.85:1 material shot from a Canon C300 and it is stretching to 16:9.”
    What is the Pixel Aspect Ratio of the footage and is Vegas Pro detecting it correctly? I know nothing about the Cannon XF codec but usually stretched video is caused by using the wrong PAR.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
