Stretching Dissolves?
Posted by Chris Franklin on May 5, 2006 at 3:17 pmForgive me for my inability to figure out the obvious, but how do you make a dissolve longer or shorter? If someone can help me out, I’d appreciate it.
Edward Troxel replied 20 years, 4 months ago 2 Members · 5 Replies -
Edward Troxel
May 5, 2006 at 5:58 pm -
Chris Franklin
May 9, 2006 at 6:00 pmThanks. I was hoping and trying to just “butt” the two clips together on the same track and drop the dissolve between them, but I guess I need to just put them on two separate tracks. –I knew I could do it this way and drop the transparency on both of them, but I was hoping for a faster way.
Thanks for your help
Edward Troxel
May 9, 2006 at 7:07 pmDon’t use two tracks… USE ONE! Just overlap the two clips and instant crossfade. It’s so simply I wouldn’t ever use two tracks without some specific reason to do so. The bigger the overlap, the longer the crossfade. If you want something besides a crossfade, just drop the desired transition onto the crossfade.
If you insist on butting them togther, just press “/” on the numeric keypad to add a crossfade.
Chris Franklin
May 9, 2006 at 8:50 pmThanks a lot man. I knew there had to been a better and faster way than what I was thinking. This was my first Post and I appreciate your responses. Thanks.
Edward Troxel
May 9, 2006 at 9:04 pmSince you’re just starting, you might want to take a look at my newsletters at http://www.jetdv.com and, particularly, the “Beginner’s Corner” series that begins in the 4th issue. While geared to the full version of Vegas, most of the concepts also apply to the Movie Studio versions.
