Activity Forums Adobe After Effects stretching a composition
  • stretching a composition
    Posted by Alistair Chisholm on August 19, 2005 at 2:24 pm
    i have made a series of 5 second compositions with fairly complicated animations. What is the best way to change the length of these compositions without stuttering the film?
    Filip Vandueren replied 21 years ago 2 Members · 1 Reply
  • Filip Vandueren
    August 19, 2005 at 7:27 pm
    depending on the complexity of the comp it can be a real pain.
    Because when you selecty them all and then stretch them, their startpoints don’t shift to the correct time.
    There might be a script on aenhancers.com
    But here are some work-arounds that might work for you:
    pre-compose them and then time-stretch the pre-comp.
    Or
    render to a higher framerate (eg. 35fps), re-import and comform to your original framerate (25 for PAL) this would slow it down to 35/25 = 140%.
