Activity Forums Adobe After Effects Stretched glow on 32 bpc
  • Stretched glow on 32 bpc
    Posted by Tylor Larson on April 23, 2012 at 9:17 pm
    i was just playing around in AE and ran into a serious issue. i made a simple shape layer that is a circle. I then applied a Glow affect and change the BPC to 32 floating. and now the glow is in a oval shape and not circular. Can some one explain to me what is happening with this? attached is and image to explain.
    4027_glowissue.jpg.zip
    Tylor Larson replied 14 years, 4 months ago 42,190 Members · 2 Replies
  • Tylor Larson
    April 23, 2012 at 9:34 pm
    i did figure out how to remove the stretching… if the threshold on the Glow is set to zero you get an oval… but if it is set to 100 then it turns into a circle… i just need some one to explain why this happens…
    Ty
  • Tylor Larson
    April 23, 2012 at 9:41 pm
    the comp is a square pixel 1920×1080 29.97. the circle is a Shape layer with a white fill… which might explain the white ramp…oh… And the glow is based on the alpha channel… radius is 138 and intensity is 9.6.
    TY
