Activity Forums Adobe After Effects Stretch vs. Interpret Footage
  • Stretch vs. Interpret Footage
    Posted by Bruce Gaber on September 27, 2016 at 6:10 pm
    I do a fair amount of time manipulation of video footage and I’ve been using Interpret Footage to change frame rates. But I’m wondering what, if anything, is the difference between that method and stretching/contracting the footage using Stretch function in the timeline.
    Bruce
    Photographer / Motion Graphics Artist
    Vision Rising
    vimeo.com/BodhiBruce
    visionrising.com
    Dance Without Reason
    Tero Ahlfors replied 9 years, 7 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    September 27, 2016 at 7:18 pm
    With interpret footage you are setting the footage/sequence to run at a different frame rate. So the duration changes but you are seeing every frame there is. When you are time remapping the footage AE (or whatever program you have) will need to create or remove frames.
    So for example if you edit 24 fps footage to a 25 fps sequence without interpreting it there would be an extra frame at the end of each second to keep the duration the same. Editing a 60 fps footage into a 30 fps sequence would drop every other frame.
