Activity Forums Adobe After Effects stretch time of Compositon not work ( MotionFactory plugin)
  • stretch time of Compositon not work ( MotionFactory plugin)
    Posted by Arioman Manos on September 23, 2018 at 8:31 pm
    hi , i use free version of Motion factory and Type Builder Plugin for create some Text Effect
    the Problem is the Time of Composition is too low ( about 2 sec ) , i want to increase and extend this time to more like 10 sec
    I Try to use Time > Time Stretch on Composition , the Composition bar stretched but when i play it my text animation is still from 0 to 2 second and then show blank
    Even i try to open composition and time stretch all layers but no success again
    Mark Whitney replied 7 years, 11 months ago 2 Members · 1 Reply
  • Mark Whitney
    September 23, 2018 at 9:50 pm
    Are you sure that what you want to do isn’t actually just simply INCREASE the duration of the comp & not stretch it which generally changes time scale?
    I suspect you are.
    With your comp selected, hit Ctrl-K. That’ll bring up your comp settings. Towards the bottom where it says Duration:, enter what you want there. It’ll be frames or time depending on what you had set in the timeline.
