Stretch problems exporting from FCP 7 to iDVD via QTM
I am getting stretch problems when I export from FCP 7 to idvd via QTM. I have been trying to cure this problem for four days and the client is waiting patiently for the DVD.
My time line settings in FCP 7 are:
Frame Size 720 x 576. Aspect Ratio CCIR 601/DV PAL (5:4). Pixel Aspect Ratio PAL CCIR 601 (720 X 576) Anamorphic Box is UNCHECKED
Field dominance: upper
Ed Timebase 25
compressor DV – PAL
Compression settings DV – PAL
Quality-Best
Interlaced
4:3
The pictures in FCP are fine but when I export to QTM they become stretched. Also when exported to iDVD. I have tried to change the aspect ratio anywhere I can including in idvd picture settings but when I burn the DVD the images are stretched, everytime. Instead of a true 16:9 image it’s just a stetched 4:3. How do I keep the correct aspect ratio during this process?Regards,
Tony Belmont
