Activity › Forums › Adobe Premiere Pro › Streaming video
Streaming video
Posted by Eyal Gordin on June 3, 2005 at 5:50 amHi
I have a 5 min PPRO movie that I exported as QuickTime movie in 3 sizes. When you click on the icon in my site, it downloads the clip and plays. How do I stream it so it starts playing right away?
https://www.framedmemory.com/reel.htm
EGGreg Cotten replied 21 years, 3 months ago 3 Members · 16 Replies -
Greg Cotten
June 3, 2005 at 7:53 pm[START CODE
[END CODE]
Just replace the links and width + height parameters. Then put that in Notepad, save as .TXT, and change to .htm
-Greg
Mike Velte
June 3, 2005 at 9:00 pmIt buffers about 10 seconds on my PC before playing. Your connection might be skinny.
The other alternative involves an RSTP server, a “Hinted” for streaming file with several “audiences” included. The server will determine the connections speed and deliver the appropriate audience.
Eyal Gordin
June 3, 2005 at 9:37 pmMike,
Thanks. It works great just the page has [start code] and [end code] written. Is there a way to avoid?
EGEyal Gordin
Designer of the unique
http://www.framedmemory.com -
Eyal Gordin
June 4, 2005 at 12:05 amNever mind, I just deleted the brackets. What are the best settings for a high res stream?
Eyal Gordin
Eyal Gordin
June 4, 2005 at 5:31 amHi
Although I posted a general question, I’d love to hear from you since you were kind enough to give me this HTML code.I’ve exported my 5 min PPRO clip to QuickTime and tried to get the best res with the largest size streaming video. By setting it to LAN, it won’t go past 320×240. When I try to manually up it to, say, 400×300 the results have some unstable video with lines appearing randomly. Is there a way to get it bigger but to keep the res? I know it comes with a price of a bigger file.
EGEyal Gordin
Mike Velte
June 4, 2005 at 11:41 amPro cant effectively export QT files for the web. The Sorenson Basic codec is lame. Windows media Video or Real Media will work much better. Video resolution should remain 4:3 and divisible by 16, like 480×360. Bitrate between 250 and 1000 kbps can be used, but the restraint is the target’s connection.
If you really need QT, then buy Squeeze…it has the Sorenson Pro codec which is fine. -
Eyal Gordin
June 5, 2005 at 10:01 amHi Mike,
By Windows media video, do you mean media player? or it is a software I need to acquire? 480×360 would be great if I can keep the sharpness. Bit rate wise, the larger the better?
EGEyal Gordin
Mike Velte
June 5, 2005 at 11:52 amWindows Media Video (.wmv) is Microsoft’s video compression done in Pro’s Media Encoder or a free encoder from Microsoft. The higher the bitrate the better, to a certain point. 2 pass Bitrate VBR at 480×360 at 1 mbps should work well.
Eyal Gordin
June 5, 2005 at 5:31 pmHi Mike,
Well, I picked Windows AVI from the media encoder. Then I tried high quality broadband and that was pretty crappy. I’m trying now the 1024 download and I had to change the size because it defaults to 320×240. Are these the correct choices?
EGEyal Gordin
Mike Velte
June 6, 2005 at 11:34 amThe Presets are just a starting point to create custome presets. Sounds like you are in the right direction, except there is no AVI…just Windows Media.
