Activity Forums Avid Media Composer Streaming Vector Scope
  • Streaming Vector Scope
    Posted by Accountneedsrealnameupdate on August 3, 2006 at 7:08 pm
    I am working with a Panasonic HVX200 and Avid Xpress Pro HD. I can connect the camera via firewire and stream live into Avid and I can load a clip into the color correction toolset and open a vector scope or waveform monitor, but I cannot seem to do both at the same time. Is it possible to use Avid as a real time scope?
    Erik Hermesman replied 20 years, 1 month ago 3 Members · 4 Replies
  • Jon Zanone
    August 4, 2006 at 11:32 am
    No – you’ll need (and want) external scopes. Avid scopes are not real time, to the best of my knowledge.
    If you look at the digitize tool, you’ll see a little vectorscop icon. Click on that and you’ll get a vector/WFM you can use on analog sources. Since you can’t usually adjust the video levels via a TBC using SDI or Firewire, you won’t have the option of using a scope.
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Accountneedsrealnameupdate
    August 4, 2006 at 7:51 pm
    No adjustment, No Scope. Makes sense. I need to match two cameras in the field and want to minimize the amount of gear we are a hauling around. Does anyone know of a software based vectorscope that could rum on a laptop and work with 60p over firewire from an HVX200?
  • Jon Zanone
    August 5, 2006 at 12:25 pm
    I’ve heard good thing about SeriousMagic’s DV rack…
    jz
  • Erik Hermesman
    August 6, 2006 at 3:28 am
