Activity Forums Media 100 StreamClip Settings
  • Floh Peters
    November 4, 2006 at 7:45 am
    From MPEG Streanclip, export as Media 100 i 720 codec file (either PAL or NTSC), with a high data rate setting. This way you have to recompress only once, and for PAL you will stay in the DVD resolution (720*576), while for NTSC you only have to do a small conversion (480->486 lines). You probably will not notice any differente wether you will use e.g. 70% or 90% quality, since the source material (DVD) is somewhat limited.
