Activity Forums Compression Techniques Streamclip Not Playing Video Properly…
  • Streamclip Not Playing Video Properly…
    Posted by Mark Pybus on April 13, 2013 at 10:16 am
    Hello,
    Whenever I load a file into Streamclip (1.9.2), the top 1/5th of the video is cut off. This happens regardless of what type of file I load into Streamclip. When I export from Streamclip, the exported file is fine, but I’m not able to properly view the file before the export.
    This is problematic as the files are quite long and I only want to export certain clips.
    Any thoughts?
    Thanks.
    Macbook Pro 2.4Ghz
    16MB RAM
    OS 10.8.2
    Craig Seeman replied 8 years, 10 months ago 4 Members · 3 Replies
  • Jeff Greenberg
    April 15, 2013 at 4:02 pm
    Since everything is working fine, but it’s not displaying okay, this leads me more to believe that something odd is going on with your user than anything else.
    A quick & dirty solution would be to trash the prefs: it.alfanet.squared5.MPEGStreamclip.plist
    If that doesn’t work, see what happens if you create a new user and if the problem remains.
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
    New! Come see me speak @ NAB/Post Production World!
  • Mike Weber
    November 15, 2017 at 10:45 pm
    I had this same problem. This solution worked for me:
    1) Be sure you have the most recent BETA version (1.93b8)
    2) Open Applications folder, select MPEG Streamclip’s application file, do “Get Info” (command-I)
    3) check “Open In Low Resolution”
    4) MPEG Streamclip should now work correctly.
  • Craig Seeman
    November 15, 2017 at 11:12 pm
    Alas MPEGStreamclip developed stopped years ago. Note the beta (from 2012) never became a release version.
    VLC is still very much alive for Playback and HandBrake for encoding otherwise it’s time to move on to other players.
