Activity Forums Compression Techniques stream to jpeg
  • stream to jpeg
    Posted by Nayan Kapadia on June 3, 2010 at 5:19 am
    HI,
    I have converted image from live stream using ffmpeg -i rtsp:///main.mp4 -an -r 1 -y -s 320×240 video%d.jpg.Using this I obtain continous jpeg images. Is there any way to generate only one image and overwrite that image after each frame using ffmpeg?
    Another thing,I am using ffmpeg on windows.When i type ffmpeg.exe in command line it displays ffmpeg version message and configuration message, how can i stop display of these messages on command line?
    Thank you,
    NBK
    Michael Rampe replied 16 years, 2 months ago 2 Members · 6 Replies
  • Michael Rampe
    June 3, 2010 at 5:40 am
    [nayan kapadia] “Is there any way to generate only one image and overwrite that image after each frame using ffmpeg?”
    Do not use the “%d” in the image name. This is what creates sequential image numbers.
    The “-y” flag will overwrite the previous image which you are using. Try putting it just before the output filename.
    Eg.
    ffmpeg -i rtsp:///main.mp4 -an -r 1 -s 320×240 -y video.jpg
    This might work or might just create one frame and stop. Not too sure about this. Try it and see.
    [nayan kapadia] “When i type ffmpeg.exe in command line it displays ffmpeg version message and configuration message, how can i stop display of these messages on command line?”
    You cannot stop this display.
    Michael
    “half-way to world domination A.K.A. the belligerent blue bike shed”
  • Michael Rampe
    June 3, 2010 at 6:09 am
    Just tried to replicate it and it didn’t work. Just wrote one frame and failed.
    I will keep looking into it.
    What is the intended purpose for this process? There might be a workaround if I know what you are trying to achieve.
    Michael
  • Nayan Kapadia
    June 3, 2010 at 10:27 am
    Thanks for your reply. I can generate image only once not able to update image.
    Thank you,
    NBK
  • Michael Rampe
    June 3, 2010 at 11:57 pm
    Yes, it fails after one frame.
    What are you trying to achieve?
    Michael
  • Nayan Kapadia
    June 4, 2010 at 9:06 am
    I want to update and overwrite image from live stream continously and want to display in server.
    NBK
  • Michael Rampe
    June 7, 2010 at 7:18 am
    I cannot think of a way to do what you need within FFmpeg but it could be easily solved writing a shell script.
    The command that produces the single frame takes less than a second on my setup. Seeing that you have specified the rate to be 1fps for pulling the frames, you could write a script that calls the same command from FFmpeg every second overwriting the previous frame and thus producing the desired result.
    Michael
