Activity Forums Apple Final Cut Pro Legacy Stream Problem on HDV import
  • Stream Problem on HDV import
    Posted by Uli Kunkel on August 17, 2007 at 1:42 am
    I’m using the Sony Z1U and during digitizing I’m getting a message that says “Steam Problem There was a problem with the stream. There might be a problem with your tape.” or something to that effect.
    The tape plays back beautifully and there weren’t any hangups during shooting.
    I shot 1080i50 and all of my settings are correct in FCP, as I’ve done this many times before.
    The tape was brand new. Any ideas how to fix this?
    FCS 6.0.1
    Michael Palmer replied 19 years ago 2 Members · 3 Replies
  • Michael Palmer
    August 17, 2007 at 2:39 am
    I assume you are capturing native over firewire, is there any other way that you can capture, component into a capture card????
    Is this the only tape you have an issue with?.
    Michael Palmer
  • Uli Kunkel
    August 17, 2007 at 3:49 am
    I shot only this one tape, so it’s the only tape I know of.
    Thankfully I have my Kona card and capturing into that worked fine. However, I lose my timecode. VERY frustrating.
    This is why I hate HDV.
  • Michael Palmer
    August 18, 2007 at 12:33 am
    I believe you can take a DV signal (as if you were down converting HDV to DV) out of the Firewire port off the camera/deck straight into the Mac and setup the device control for DV in the L&C Capture settings tab and set the Capture Input as DVC Pro HD.
    Good Luck
    Michael Palmer
