Activity › Forums › Adobe After Effects › streak effect
  • streak effect
    Posted by Aebeginner on November 6, 2005 at 4:01 pm
    Hi all
    I am trying to find a quick method to achieve a streak like effect.
    not a light rays but an effect that takes part of the picture and stretches it into straigt lines.
    used extensively by MK12 in many clips.
    Thanks in advance
    Jasper
    Serge Hamad replied 20 years, 10 months ago 3 Members · 3 Replies
  • David Johnson
    November 6, 2005 at 11:12 pm
    I’m rendering right now so i can’t look to be sure, but sounds like you might be looking for CC Smear or Scale Wipe. I also seem to recall using an effect with stretch in the name, but I think it is a third-party plugin. Haven’t seen the MK12 clips your refer to, but there are many other ways to stretch clips in AE…depends on specific look you want.
  • Aebeginner
    November 6, 2005 at 11:35 pm
    scale wipe is kind of the look I am looking for…although it distorts proportions of the image,
    It doesn’t give nice lines, everything becomes fat and distorted (same and even worst with smear)
    but this is the direction!
    Jasper
  • Serge Hamad
    November 6, 2005 at 11:39 pm
    The Smear plug-in from http://www.petewarden.com can do that. Any Tinderbox plug-in with the Source Crop set to repeat would do the trick.
    The Effect>Channel>Minimax can also produce your effect. here is an example at the beginning of the animation:
    https://www.nyc-visual.com/minimax.mov
    I would also advise you to use the effects on a masked adjustment layer to alter only the necessary parts of your clip or graphic.
    Salut.
    Serge
