Activity Forums Apple Final Cut Pro Legacy Strange watery effect after color corretion?
  • Strange watery effect after color corretion?
    Posted by Harry Powell on January 6, 2010 at 8:39 pm
    I’ve got a person standing in front of a window talking to camera.
    I used two Color Corrector 3-way filters (one with limiter) to improve the picture, i.e. by boosting the person’s exposure, and dampening down the brightness from the window so that it isn’t completely bleached out. I’ve also added a Broadcast Safe filter.
    The above looks OK except when I press play, even after rendering. I get a strange ‘watery effect’ on some parts of the picture (not the white parts). By ‘watery effect’, I mean similar to the moving pattern you get under a bridge caused by sunlight bouncing off a river below. The effect is also there when not playing, only less noticable because it isn’t moving.
    This is ProRes taken from AVCHD if that’s relevant.
    Harry
    p.s. Happy New Year folks! And hope deadlines didn’t interfere with the season to be jolly!
    Harry Powell replied 16 years, 8 months ago 3 Members · 3 Replies
  • Chris Poisson
    January 6, 2010 at 10:07 pm
    I have noticed a “watery” effect on footage to which the smoothcam has been applied, but never to what you are talking about. I would trash my prefs if I were you.
  • Michael Gissing
    January 6, 2010 at 10:20 pm
    The problem is most likely the limit effect 3WayCC. Try softening the HSL (slider at the bottom) and also play with edge trimming.
  • Harry Powell
    January 8, 2010 at 1:24 pm
    Adjusting the sliders does improve things, by making the effect more more diffuse but I can’t seem to clear it fully.
    Bit nervous to delete preferences right now in middle of impossible deadline (particularly as FCP Rescue 6 link seems broken – and I think there are reports that it doesn’t work with Leopard?). But I’ll give it a go when I can.
    Thanks for your replies.
