Activity Forums DaVinci Resolve Strange vertical lines covering image
  • Strange vertical lines covering image
    Posted by Jim Rage on December 9, 2019 at 5:38 pm
    Just shot some footage on a BMPCC4k that looks fine in the camera, but when I try to bring it into resolve it’s all messed up (see pictures.)
    I’ve tried:
    Quitting and restarting
    ejecting the and replugging in the media source
    Creating a new project
    Looking for folks online with the same problem (yielding no matches)
    The footage is still fine on the camera and I can even see it playback fine in the thumbnails, but whenever it’s in the viewer it’s covered in white lines. When I press play it clears up a little bit, but is still unusable. It doesn’t matter if it’s in the editor, the color corrector, or anywhere else in resolve it plays back the same way. When I open the RAW file in image viewer the preview appears fine. I shot some footage with the same settings a few weeks back and had no problems, BUT now all of that footage is covered in lines as well. When I export from resolve the exported file is also messed up.
    I updated to Catalina in between and I’m suspicious that the update may have screwed things up.
    I was shooting in:
    4k
    Blackmagic RAW
    Constant bitrate 3:1
    23.98 fps
    Jim Rage replied 6 years, 9 months ago 1 Member · 1 Reply
  • Jim Rage
    December 9, 2019 at 6:38 pm
    Welp, the fix was pretty simple. Updated from 16 to 16.1. Everything works fine now.
