Activity › Forums › VEGAS Pro › Strange timestamp/text appears on exported xvid avis
  • Strange timestamp/text appears on exported xvid avis
    Posted by Morgan Rekhi on August 3, 2008 at 4:04 pm
    Hi guys, major problem here…I’ve been using Vegas for over a year and always export my work as Xvid avi files. Always looks fantastic. But suddenly, just last night, I tried exporting a new project and there is this bizarre stamp on the top left of the frame with rapidly changing numbers, and then another line of text below it.
    Screencap:
    https://i196.photobucket.com/albums/aa148/thegingerkids/vlcsnap-55666.png
    I thought that perhaps it was related to the source footage, so I went back and tried reexporting one of my previous projects and the same thing is happening. Everything looks fine when exporting in wmv, and probably will work fine in any other format, but xvid exports are subject to this stupid text. Has anyone run into this issue before? Any suggestions on what might be causing it would be so much appreciated. I use Vegas 7. Thanks!
    Morgan Rekhi replied 18 years, 1 month ago 2 Members · 2 Replies
  • Steve Rhoden
    August 3, 2008 at 9:04 pm
    Sorry to say i haven’t.That embedded time-code is not coming from Vegas but if you did not mention it, i would have definitely said
    it was your source footage.
    Probably you can check the customizing of the xvid codec when you
    are rendering to see if some action prompts this.
    I don’t use xvid for a number of reasons so i cant be too specific
    where this codec is concerned.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    http://www.youtube.com/hentys
  • Morgan Rekhi
    August 3, 2008 at 9:23 pm
    Hi…thanks, I actually seem to have figured it out. It was coming from Vegas – had to be, there’s no other option. The source footage was fine but the text appeared upon being exported so…don’t see where else it would be coming from. However, after a bunch of different options, I just tried resetting the xvid config stuff to default, and then readjusted it from there. Seems to be working now. Thanks anyway!
