Activity › Forums › Apple Final Cut Pro Legacy › strange time line in fcp
  • strange time line in fcp
    Posted by Ram Prasad on September 4, 2010 at 8:04 am
    i get this strange time line when i try to move in the time line.it trails.
    using a new i mac with intel core 2. 4 gb ram
    ati raedon hd graphics.
    but this doesn’t goes off.
    re installed final cut.
    but the problem continues .
    Ram Prasad replied 16 years ago 2 Members · 2 Replies
  • John Pale
    September 4, 2010 at 8:40 pm
    How did you re-install?
    FCP is difficult to uninstall (many components and frameworks). Usually, it’s advised to wipe your drive and clean install the OS and the Final Cut Studio. If you don’t do this, the corrupt files may remain or you could end up with an incomplete installation.
    If you have clean installed and you are still having problems, you might consider bringing your iMac back to the Apple Store or wherever you bought it and have it checked out (including the RAM).
    If you bought and installed 3rd party RAM yourself, remove it and put in only the RAM preinstalled by Apple and see if the problem goes away. Incompatible or faulty RAM often causes weird issues like this.
  • Ram Prasad
    September 5, 2010 at 5:05 pm
    thks john pale.as u said there had been some corrupted files.
    i did a clean install .
    now evrything is fine.
    works perfect thanks for your info..
    have a grt life bro.
    care
    ram
