Activity Forums Adobe After Effects strange TGA SEQ export problem
  • strange TGA SEQ export problem
    Posted by Paul Allman on August 15, 2006 at 9:49 pm
    Hi – I have searched the posts and found nothing about this: rendering out a patch for an HD (1280X720) sequence, discover that the match-frame is darker in the new exported frame. Original seq was rendered on a different Mac dual G5 running Tiger. The same drive and project attached to dual G4 running 10.3.9 and same version of AFX (6.5) produces a significantly darker image. No changes, same project. My Quicktime is 7.1.1, hers 7.1.
    Image in the AFX timeline is not darker. only darker when exported to TGA, using identical output module.
    Is this a QuickTime thing? OS thing? Thanks for even thinking about it.
    Allmanic
    Paul Allman replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
