Activity › Forums › Adobe Premiere Pro › strange sub-clip behavior, open-ended out?
  • strange sub-clip behavior, open-ended out?
    Posted by Paul Dougherty on May 3, 2016 at 1:09 pm
    I saw many people post the same problem on the Adobe forum but don’t see a solution
    I’m at home so I can’t offer the Premiere version (almost sure it’s the latest) but when I edit a sub-clip into my time line the (say) 2 sec clip will run the length of the original master clip… unless I manually set marks on it. Yes “Restrict Trim to subclip boundaries” turned off, but this never used to happen
    Thanks in advance,
    Paul
    p.s. I did search on sub clip limits
    Dennis Callan replied 10 years, 3 months ago 2 Members · 1 Reply
  • Dennis Callan
    June 15, 2016 at 7:08 pm
    Trash prefs to fix this. New subclips will no longer have this problem, but subclips defined before trashing will retain that open-end bug.
