Activity Forums Apple Final Cut Pro Strange selection behaviour when expanding audio / video
  • Strange selection behaviour when expanding audio / video
    Posted by Brendan Gibbons on June 29, 2011 at 10:01 pm
    Is anyone else experiencing strange selection behaviour when expanding audio / video (ctrl+S)
    Let me explain what’s happening to me…
    Sometimes, but not all the time, when expanding the audio / video, the clip that was selected stays selected and you can’t select anything else….until you use the keyboard shortcut again to collapse.
    Double-clicking with the mouse will not collapse the tracks either. But doesn’t seem to happen all the time.
    Also when the audio / video tracks are expanded, I have found that you have to drag a VIDEO effect onto the AUDIO track before the video track highlights white and let’s you apply. But selecting the video clip and then double-clicking the effect in the browser will work.
    Anyone else had this?….or is it just me and the old fatfinger syndrome rearing it’s ugly head again? 😉
    cheers,
    Brendan
    Eddie Mcfly replied 15 years ago 4 Members · 3 Replies
  • Jeffrey Carter
    June 30, 2011 at 12:25 am
    I have had it randomly stick on a clip and not be able to select anything else until you fidget around for awhile. I haven’t found a work-around.
    Seems to be just another bug…
    FCP 7 is like running track barefoot while FCP X is like running with steel toed work boots covered in cement.
  • Fred Waycoot
    August 3, 2011 at 6:18 pm
    I experienced something similar when cutting a short yesterday, but I figured it was cause I was working on my laptop and had a bunch of other apps running.
    Are you using proress? what kind of machine are you on?
    -Fred Waycoot
    Editor/Colorist/Filmmaking Guy
  • Eddie Mcfly
    August 5, 2011 at 9:56 pm
    just to doublecheck, you are on a supported system with the latest software updates? https://www.apple.com/finalcutpro/specs/ if so, what is your system and os? thanks
