Activity Forums Apple Final Cut Pro Legacy Strange repeated crashes in FCP
  • Strange repeated crashes in FCP
    Posted by Kevin Maguire on October 24, 2008 at 11:46 am
    Just approaching the end of an offline for a 1 hour doc. I have been keeping everything separated in different sequences, but have now compiled onto one timeline in preparation for fine cutting, and conform to standard def. No effects have been added yet.
    Content is 90% HVD, but a few SD clips are in there, some still pictures and text placeholders. Everything is rendered.
    When navigating through the timeline, FCP continually crashes. I’ve been crashing several times each hour.
    This crashing only started when everything was laid onto 1 timeline.
    Tried trashing prefs, to no avail. Anyone got any suggestions? Should I remove the SD stuff for now?
    Cheers.
    FCP 6.0.2
    Mac OS 10.5.2
    2 x 2.8 Quad core Intel
    6 GB RAM
    eSATA 3Tb G-Raid
    BM Decklink HD Extreme 2
    Decklink 6.7.2
    Jerry Hofmann replied 17 years, 10 months ago 4 Members · 6 Replies
  • Tom Brooks
    October 24, 2008 at 12:53 pm
    I’d try the simple stuff first, trying to lighten up the load by turning off things like waveforms and thumbnails. Possibly reset the scratch disk for those items. Next might be to suspect your stills. Are they all RGB mode, not CMYK? Then, look to disk issues, such as too-full drives or directory structure problems (use DiskWarrior). Then try a process of elimination to isolate clips or render files that might be causing the crashes. Is it random throughout the sequence? I’m relatively new to FCP trouble shooting, so I hope you get some answers from more experienced hands at it.
    Final Cut Pro 6.0.4, Mac OS-X 10.5.5, Quicktime 7.5, Adobe Prod Prem CS3, G5 Quad 2.5, Kona-LHe V6, 8.5GB RAM, Nvidia GeForce 7800-GT 256MB, G-RAID 2x1TB FW800, 6TB RAID-5 (Enhance E8-ML, Highpoint 2322), Panasonic HVX-200P P2.
  • Jerry Hofmann
    October 24, 2008 at 2:04 pm
    Render files might be causing a problem… might try trashing them all, and rendering again. Also might improve things by updating your software.. you’re several bug fixing updates behind.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Jason Porthouse
    October 24, 2008 at 3:45 pm
    Kevin,
    Had a similar thing myself… the fix was to turn thumbnails off in the timeline and trash the thumbnail cache. Helped the 3 or 4 crashes a day go down to 1 or 2 a week. This was with XDCAM and HDV. I’m not entirely convinced that the problem is down to something I’ve done, as quite a few people and differing machines are suffering from this in PAL land.
    BTW, sorry if it’s teaching you to suck eggs but to turn them off go to the sequence settings, under the timeline tab I think…
    HTH
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
  • Tom Brooks
    October 24, 2008 at 4:23 pm
    I switched to Leopard not too long ago. Everything had become very stable with Tiger, so I hated to change in some ways, but the time had come. My system is considerably more crash prone now. I have a sense that thumbnails are slow to populate the timeline and that it happens repeatedly. Before, I didn’t notice it much. Is there something new about thumbs in 6.0.4 or under Leopard in particular? The new system had thumbs on the system hard drive. I switched them to my RAID and things got somewhat better. The only thing I leave on the system drive (besides the project file itself) is autosave vault.
    -Tom
  • Kevin Maguire
    October 24, 2008 at 9:54 pm
    Thanks everybody for the suggestions. The thumbs seem the likely culprit, as crashes tend to occur when navigating in and out of the timeline or up and down using the hand.
    And yes, I need to get round to updating, but loathe to do it during a project.
  • Jerry Hofmann
    October 28, 2008 at 4:04 am
    Something else too… if you’re really crashing a lot, it’s probably best to do a clean install then update it all the way. Do it after you’re done with current project.
    Jerry
