Activity Forums VEGAS Pro Strange Rendering problem!
  • Strange Rendering problem!
    Posted by Steve Stone on January 2, 2013 at 10:46 pm
    I have Vegas Pro 11 (64 bit). I am having an issue rendering some video. All layers and elements look fine but when I render it pops up with some black frames and/or only some of the elements are active in a few frames. I shot and removed a greenscreen (ChromaKey) in some frames. Looks fine most of the way and then bam, a frame or two pops up without the chroma-key removed like it should be and is in most of the video. Not sure whats going on?? I tried all kinds of different settings but no change. 95% of the video is fine. Tried re-rendering many times.
    Anyone else run into anything like this?? Thanks!
    John Rofrano replied 13 years, 8 months ago 2 Members · 1 Reply
  • John Rofrano
    January 4, 2013 at 1:27 pm
    Make sure that you are using the latest version of Vegas Pro 11 Build 701. Unfortunately, Vegas Pro 11.0 was a bit buggy. You may want to download the 30-day free trial of Vegas Pro 12.0 and render your project with that. If it works, you just found an excellent reason to upgrade. 😉
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
