Activity Forums Maxon Cinema 4D Strange red X’s
  • Strange red X’s
    Posted by Jack Cook on December 13, 2010 at 7:44 pm
    I’m using R12 on OS 10.6.5. Been using it for a few months, and it’s working fine, but today I noticed a weird thing. Two tiny red X’s have appeared in the editor view window. They are not attached to any object, as they don’t appear in the Object manager. If I change views the two X’s are still there, in the exact same position, regardless of which view I change to (top, right, perspective, etc.). If I open a new document, the X’s are there, same place. Also, if I close Cinema and reopen it they are still there. They only appear in Cinema, not in any other program. It’s not causing a problem, Cinema still works fine, I’m just wondering if anyone knows what is going on here, or has had the same thing occur.
    Here’s a screen shot of one of them.
    Jack
    Jack Cook replied 15 years, 8 months ago 2 Members · 2 Replies
  • Tim Shetz
    December 13, 2010 at 7:51 pm
    Sounds like it might have something to do with the HUD since it shows up in the same position in every view. Maybe?
    __________
    Tim Shetz
    c4dtraining.com
  • Jack Cook
    December 13, 2010 at 8:13 pm
    You’re right, it has something to do with the HUD. In the HUD display box (where you choose what appears) I have only Projection checked. But when I go to the Filter menu and uncheck HUD the X’s disappear with the HUD. Click it back on and they come back. I have no idea what feature of the HUD they could be attached to. I opened an older file, from last Thursday, and the X’s are not there, even though the HUD is enabled and set the same way. It’s very strange.
    Jack
