Activity Forums Apple Final Cut Pro Legacy Strange Quicktime Files
  • Strange Quicktime Files
    Posted by William Bearden on September 1, 2008 at 5:34 pm
    I’ve been getting multiple, strange files when I export a QT from FCP 2. Instead of one QT file I’m getting something that looks like this:
    Part 1 trk 1-av.mov1
    Part 1 trk 1-av.mov2
    Part 1 trk 1-av.mov3
    Part 1 trk 1-av.mov4
    Part 1 trk 1.mov
    Each of the file is 2G, except for #4 which is 1.08 GB. AND, none of them will play. I’m working on a multi screen project, and need to export QTs to mpeg-2 files for a museum player. This problem has shown up sporadically for the past few months, even before I installed FCP 2. I have a 2ghz Mac Book Pro with 2gb ram.
    Thanks for any help.
    Willy Bearden
    Memphis
    Tom Brooks replied 18 years ago 2 Members · 1 Reply
  • Tom Brooks
    September 1, 2008 at 6:52 pm
    If your export is going to a drive formatted as FAT32 or is going to a share on a network there is a file-size limit that you are running up against. So Final Cut makes a reference movie which refers to a series of parts. You should be able to export the whole movie to a drive formatted as Mac OS-X Extended. If you are trying to get the movie to a network share, you can export to a Mac OS drive first and then use Finder to copy it to the network. There are a variety of ways to get there, but the format is the culprit.
