Activity › Forums › Apple Final Cut Pro Legacy › strange problem with batch capture, urgent
  • strange problem with batch capture, urgent
    Posted by Carola200 on December 23, 2006 at 8:06 pm
    hi all,
    i am having a strange problem when trying to batch capture,
    first of all, using a g4 powermac, final cut hd 4.5 and a sony GV-D300e-Pal mini dv deck
    when i log the clips i enter the in and out points, press log clip, put in a name, a comment, press ok, the clip occurs in the bin
    but when i then batch capture the in and out points have changed, if i double click on the icon in the bin, on the offline clip, it has different in and out points then the ones i typed in
    even more strange all the in points i entered become the new changed outpoints, the new mysteriously changed in points are of no logic to me.
    does anyone know what is going on?
    i cant find any place in the preferences where this might stem from
    as i am working with a tight deadline and i have to capture asap, got about 20 hours of footage, so batchcapture is the way i want to do it.
    any advise is very much appreciated !
    many thanks in advance
    carola
    David Smith replied 19 years, 9 months ago 5 Members · 6 Replies
  • Bouncing Account needs new email address
    December 23, 2006 at 8:36 pm
    The first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • Matt Galuszewski
    December 23, 2006 at 11:12 pm
    HI,
    We are running the latest version of FCP so the following is based on some dim memory.
    As PAL users we were inflicted with a bug in version 4 or 4.5 that behaved as you describe. We had a PAL DVW500 DigitalBeta deck connected and had a suitable PAL Device control selected and the system changed our entered timecodes as we logged each clip. It was adjusting the values to a 30fps rate so this only affected PAL users.
    This behaviour only occured if a tape was not inserted in to the desk at the time of logging. That is, if you had a tape inserted then the timecodes entered during logging would be correct. This bug was noted by apple and corrected in a point release.
    Hopefully this is the same for your deck….
  • Carola200
    December 24, 2006 at 10:57 am
    hi matt,
    thanks for your answer,
    tried the one with restarting and reopening, and also having a tape inserted
    the problem remained
    so now i will trash the prefs,
    if it works i ll report later
    if not maybe i can find out something more about this 4.5 bug in the net
    regards
    carola
  • Carola200
    December 24, 2006 at 11:15 am
    tried bining the fcp prefs, problem still remains…
    so do i have to reinstall final cut?
    dont know what to do…
    carola
  • Annaël Beauchemin
    December 24, 2006 at 7:22 pm
    Go to File -> Easy Setup
    Are you using a DV PAL setup?
  • David Smith
    Perhaps a workaround might be to create a batch list in a text editor and import it into Final Cut instead of creating the batch list in Log and Capture. The manual suggests exporting a batch list from Final Cut as text, opening it in a text editor and using it as a template to make sure the new one you create has the proper format and information.
    Regards,
    David
